I want to install a livewell timer switch. My current setup has the livewell pump and the bilge pump on the same switch. Up for livewell / down for bilge.
Is there a way to connect the livewell timer switch to the existing switch to avoid having to run new wires all the way back to the livewell pump? My thought is you would need to turn the existing livewell switch to the on position and then use the new switch with the timer.
Hope I am asking this question correctly. I am terrible with electrical things.
