Dual battery system. Welcaraft 180 Fisherman. Yamaha 4Stroke 115 Outboard.
The boat started strong, and I ran it for a 1/2 hour. Docked on an island, engine off, battery switch on "ALL". 3 Hours later, battery completely dead, needed to get towed in.
So yesterday I did some trouble shooting.
There was enough battery power to raise and lower the outboard.
I switched the battery switch to ALL and waited about 20 minutes. After poking around under the console, I noticed that the back of the Am/FM radio was HOT. Almost too hot to touch!!
Could this be something that could drain 2 batteries in a short amount of time?
So my plan now is to disconnect the radio, charge the batteries, then with the battery switch on "ALL", let it sit for several hours.
Any other recommendations? If the battery is still strong, then do you think I found the culprit?
Thanks.
Thanks.
