Javelin pump wiring diagram
Scott Elmore
I have a 1996 javelin 400 T/E, I unhooked the all of the pumps and don't remember which wires go to which and am in need of a wiring diagram. Could someone please help me? I have searched the forum;s and know its probably right in front of me but have yet to find it. Thank You
Ayuh,.... Power goes from the battery, to the switch, to the pump, 'n back to the battery ground,......
NYBo
Welcome to iboats!:welcome:
Not a lot of possibilities. The negatives are usually black and the positives are usually brown. Hook the negaites to the appropriate spot, and the positives, one by one, to the switches. Test, change the positive to a different switch if it's not right. If the positives are different colors, go to the pumps and see what color wires come from them. This is a bit oversimplified but hopefully gives you the general idea.
