80Starcraft
- Nov 15, 2015
- 9
I'm fairly new to boating & I recently bought this 18' Starcraft I/O, but it had no owners manual. It has both Trim Limit & Position senders, and the trim limiting & tilt work, but there's no actual tilt gauge. There is a spring loaded switch on the instrument panel, which will illuminate the two corresponding umarked lights, but doesn't seem to do anything else that I can detect. There are also 2 other lights below those that also have the lettering worn off. Does anyone have any idea what the switch does or what the lights are supposed to indicate? I'm hesitant to take it out on the water until I'm sure that everything is operating correctly, and I'm fully familiarized with it's operation.
Thanks
Thanks
