according to part list the PN of my engine harness is 862173T1 and similar 84-862163T03
any schematic for connections?
thanks
actually it's pag 9, mine does not have Knockout sensor
Thanks AD, juliolop has this correct as long as he's sure he has the Delco alternator that I'm pretty sure he does without seeing/reading the alternator. The 5.0l with an Alpha drive does not utilize the knock sensor system while had it been a bravo drive, than yes a knock system is used. juliolop, your first part number in post number one was off by one number, the 7 should have been a 6. 862173T1 and similar 84-862163T03.this is so confused, you said my SN comes wit a knock sensor installed.
this will suppose having an extra module with consequent entries in the harness,
I'm the third owner of this boat, and they assure me the engine never was changed,
I went to marinepartsplus.com and check the part list for my engine according to my SN
and they say the knock sensor comes installed in engine 5.0 bravo and 5.7 Alpha/Bravo,
where did you see mine came with this sensor and module originally?
in that hole what I have is a plug kit for drain.
thanks.
46 | 806611T | 1 | MODULE, Knock Control | (5.0L Bravo And 5.7 Alpha/Bravo) |
47 | 806612T | 1 | SENSOR, Knock | (5.0L Bravo And 5.7 Alpha/Bravo) |
