Went to start the motor and the starter cranks and cranks even after I turn the switch to OFF position. Had to disconnect the NEG battery cable to stop it. Figured I had a bad ignition switch so I replaced it with a new one I had on hand. Touched NEG battery cable to battery post and it started cranking again without the ignition switch being turned on. Bad solenoid? Any help will be appreciated.
