Acheron2010
- Apr 4, 2015
- 11
Removed the gauge panel on my 1987 Wahoo 16.2, which had non-functioning speedo, tach, and trim gauges, along with nav light switch and 12VDC receptacle.
With the opportunity to actually redesign the dashboard, what gauges are important to a vessel this size, and what would you select?
IMHO, a voltmeter would be of more value than a trim gauge - I can look at the top of the outboard to see the trim. Is there a need for a second voltmeter for a second battery, should I use one for a trolling motor?
Your experience and wisdom appreciated.
