I have a DE-251E Norcold fridge that runs great on 110V AC, but will not switch over to 12V when disconnected from shore power. I have diagnosed the problem, and have determined it is the oscillator. Fixing the fridge is not an option, and new ones are far too much $$$.
I would like to mount an inverter, and have the fridge run off of it all the time. This way it would run regardless of whether or not the shore power was connected. The battery charger will keep the batteries topped up when the boat is plugged into shore power.
My question is, how many watts does the inverter need to be? 500? 1000? Or can I get away with 100W? If the fridge draws 4 amps on 12V, is that not just 48 watts?
Thanks!
Thanks!
