reyrolando
- Sep 23, 2015
- 1
I have a 96 Evinrude 225. I removed the original key and starting system and replaced it with a push start button as you would see on cars. In doing so I had to disconnect the choke wire. So now I have no choke.
I would like to do is and this is my question. Can I connect the purple and white (primer) wire to a wire that is in use, such as the red and yellow (starter) wire? Or is there another wire I can use that the choke wire tap into?
