TBarCYa
- Apr 13, 2005
- 781
I have the 50s installed in my 2008 Maxum and decided to mount the transducer on the transom instead of a shoot thru hull like gpsmap 440s that's also in the boat. For whatever reason the 50s will not read when on plane which usually means it's mounted in a bad place but I've tried 2 locations and neither is any better than the other. In the pic you'll see where it is now and the bright white 5200 that's filling the holes where it originally was mounted. Any suggestions on what I can try to get it to read would be awesome.
