oldboat1
- Apr 3, 2002
- 9,607
I have an electric start trolling motor on a larger boat I keep in a slip. Just bought a solar charger for the little motor?s starting battery that is in a battery box at the stern ?-- $25 at Tractor Supply. It?s a Coleman 2amp charger.
I hung around a little after hooking it up to see if it was charging, and think it is. I had only a portable state-of-charge meter on the boat, but see a slight increase in charge after sitting around reading the Sunday paper for a while, so think it?s probably working OK. Do these little rascals heat up with use? I have it on top of the battery box, with a bungie cord to keep it in place with any rocking or wind action. I also cleverly used the molded plastic top of the bubble pack to cover it from rain ? think it?s probably not waterproof.
It looks like the recommended application is at the windshield, attached by supplied suction cups (which probably have no chance of holding). Additionally, it seems to me that summer heat at the windshield would be pretty high. It?s a plastic case, after all.
Any thoughts on using these devices? It?s use and application issues I?m most curious about, in an actual boat in the actual weather. I don?t want to bother with any wiring to the regular house or starting batteries or the onboard charging system ? and figure a 2amp trickle charge would be fine. The little 9.9 puts out only 5amps, I think, and that would be at higher rpms.
[BTW -- deep cycle marine battery. I mention that because an auto supply store clerk mentioned that our Mennonite neighbors here (finger lakes, upstate NY) use these chargers for running lights on their buggies -- have the idea the batteries in use would be small lawnmower/motorcycle batteries. Anyway, I figure ongoing use on a marine deep cycle would likely be fine, and would like to just leave it connected. Any history of boat use would be nice, particularly if there are some hazards....]
