albertwnak
- Aug 1, 2015
- 2
we have a 2006, 2450 Bayliner and we want to use a eb3800x Honda for shore power while its home and in a shed that does not have regular electricity, problem is as soon as I plug the boat to the generator the circuit breaker trips on gen set. I have put in a separate ground stake for the gen set, tried a common neutral plug on the outlets of the gen set because the boat has a floating neutral. every thing works fine when plugged into normal power , just a problem with generator
any suggestions ? thanks
