I decided to turn my deck up pretty high (higher than normal) and it went out (completely lost power). This happened several years ago and I remember troubleshooting it, and fixing it but I can't recall how. I thought a "inline" fuse was blown so I pulled the deck from the mount down in the cabin and followed the yellow wire as far as I could and to my surprise no inline fuse (i thought thats what it was last time I did that). I then proceeded under the helm and check all the fuses with a continuity check and all checked out fine. I then pulled the power panel and checked the switch in the cabin and power is being supplied to and from the switch. I then checked the yellow wire for continuity between the deck and the plug behind the power panel and it checked out fine. I then checked the power from the yellow line behind the power panel and it had no power . My thought is their is some damn inline fuse but for the life of me I can't find it and the deck is not getting power; I am at a loss . I navigated the wires all under the helm but I don't see any inline fuse under there that I could track to another device. Does anyone have the same setup and can point me in the right direction? I pulled the dash apart and found nothing as well.
Thanks for taking the time to read my post I am hoping I can get some music by the weekend.
Cheers!
Cheers!
