Caseyshoe27
- Jul 30, 2015
- 5
I have an older bass boat, 90 stratos 285 pro. I recently upgraded my trolling motor. It previously had a 12/24v omc 55lb trolling motor which was plugged into a 4 prong female receptacle. The foot control had a toggle switch that let you choose to run 12 or 24v.
My new motorguide 24v 65lb thrust is 24v only it has only 2 wires (red and black). Is it possible to wire the two wires to the old 4 prong male plug to where I can pull 24v out of the original female receptacle?
I tested the female socket and my grounds are the top and bottom slots and my positive slots are the left and right. I get 12v on each left and right side when I ground it to the top or bottom slot. The batteries are not run in a series they have a positive and negative on each battery running straight to the female plug.
How can I wire my original 4 prong male plug to get 24v to my new trolling motor? I would like to not rearrange any of the wires on the bottom of the female outlet because it has 20 year old silicone over every terminal. If possible a wiring diagram would be very appreciated. I would like to use the original plugs if possible and I don t want to hard wire it to the trolling motor. Thanks!
