Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
1964 Starcraft Jet Star Renovation
This topic is closed.
  • 1964 Starcraft Jet Star Renovation
    I came across this aluminum Stracraft on Craigslist. The price seemed right at $750 (got it for $700) and basically the hull and transom are in good solid condition. The outboard I'm not too thrilled about and will most likely be looking for something else around 40-45hp, max listed on the capacity plate is 45.
    Classic Ugly:
    Port & starboard (the speckling is mud splatters):
    Front deck is real grungy, more so than the rest of it as it has been exposed to the elements because of a short tarp. It's been repainted and would look nice if I can get it cleaned up. It's a sort of metal flake burgundy.
    Stern with 50hp 1964 West Bend power. I know it runs but I haven't started it myself yet.
    Helm: I envision a new wood dashboard & plan to ditch the compass (points south!), speedometer & depth finder. New controls and steering when I change the outboard. Current steering is pulley & cable.
    My project (with index): 1964 Jet Star: http://forums.iboats.com/forum/boat-...nabout-project
    Completed condensed version: The Permanent Vacation
    Make a New acrylic windshield: http://forums.iboats.com/forum/boat-...craft-jet-star
    Re: 1964 15' Starcraft Aluminum Runabout Project more pics
    The entire interior needs to be gutted. The floor is so rotten I can break it out by hand, and don't know if I'll be able to save it in pieces big enough to use for templates.
    I'll probably go with classic back-to-back lounge seats:
    • #3
      Re: 1964 15' Starcraft Aluminum Runabout Project & more pics
      A couple more:
      • #4
        Here's the new power for the craft. I've been trying to sell the 50 West Bend on craigslist, ebay and another website, with some interest, but have a prospect now that looks like it might fly. The "new" Johnson is a 2003 that's waiting it's turn in the shed. It has oil injection, no pre-mixing of oil & gas.
        • #5
          Here you go. This is out of the 64 brochure. Jet or Jetstar are identical except for the seats.
          Sorry I had to do it in pieces-the page was too big for my scanner.
          BTW, I might be convinced to take that steering wheel set up off your hands if you decide to let it go
          sigpic
          Sunchief In Motion!http://www.youtube.com/watch?v=IOO34zeE_Vg
          Sunchief Restoration! http://forums.iboats.com/showthread.php?t=286412
          • #6
            Man, it's amazing the info you can find on these boards! Thanks, North Beach.
            I managed to sell the West Bend a couple days ago, so now I'm ready with a plan.
            • #7
              Here's a shot of the transom wood at the knee braces. I don't know how the original looked, this is a replacement board.
              Here's a shot of the exterior of the transom. It looks as though I'll be able to go straight across without much modification, just replacing the cap with a straight one, in order to accomodate the long shaft Johnson. I might have to cut a notch out of the corner caps, but don't know because I haven't done my detailed measurements yet.
              After cleaning out the rotten floor and water-soaked styrofoam, the inside of the hull was cleaned out. I used brake cleaner spray to remove the stubborn oil/gas, and did lots of scrubbing with an all-purpose cleaner and a wire brush, and periodically hosing it down and letting the slurry drain out the drain tube.
              • #8
                I anticipate my use being 2-4 people just cruising around, don't plan to fish or ski or tube.
                Thinking about seats, I was originally wanting to go with lounge seats, but hit on a mounting idea using the original design of the boards and original brackets. It saves me raising to a flat floor to mount the lounges. I didn't want to be sitting that high. Once you get up to level you lose 5-6", and another 10" base height plus cushion. The new plan will keep the center of gravity lower too. I want to feel like I'm sitting in the boat, not on top of it.
                • #9
                  I started removing the transom, removing the original style nails. Some came out easily that I could grip with the hammer claw. The others are going to be less fun.
                  • #10
                    Next phase: trying to remove the transom wood.
                    My plan was to get the current wood out in one piece so I could use it for a template while transforming it from a 16" transom height into a 20" for my motor. I got all the trim & bolts removed and the zillions of screws attaching the back of the splashwell, that was all relatively easy. Removing the wood is not so easy, it's stuck in there really tight.
                    I thought I had a good plan to put screw eyes in the current wood, which it turns out is quite solid, and rigging up a car jack to try to pull it out. But that didn't work out because as I had anticipated it might do, all it did was lift the boat off the trailer.
                    In the process I discovered that the curved corner pieces the PO had put in when he replaced the wood weren't even fastened in, they were just sitting on top of the 2x10 underneath it. The 2x10 itself is actually in pretty good shape.
                    I need to adapt my transom for the 20" shaft Johnson. When I was motor shopping, I was having a heck of a time finding a short shaft 48-50hp. With a 20" transom, the cavitation plate above the prop should be even (within 1") of the bottom of the boat.
                    I'm pretty hopeful on the performance with the 50 hp. The capacity plate rates the hull for 45 hp, and the 1964 brochure says 50. Motors were heavier then; using the USCG guide, with a 20" transom, that formula estimates about 60 or 65, but I would never go that high on this hull. I'm sure the 50 will be more than sufficient for my wants.
                    What's left of my plate, more like a sticker:
                    • #11
                      New seats arrived today!
                      I picked these up new on ebay for $170 including shipping after exhaustive research basically trying to compare apples to oranges. They were well packaged. I unpacked them and gave them a good going over to make sure all was well. They are comfortable, if not just a bit harder than I expected, but that's better than sitting and squashing the foam down to the base. Overall quality looks very good, sturdy & well constructed etc. This was labeled as "Wise Deluxe" model, I but haven't been able to find any identical ones anywhere else.
                      With my color plan for a red exterior and gray interior, I think they'll look pretty good in the boat.
                      • #12
                        After winter passed, I got the transom wood out in about 10 minutes by pounding on the bottom of it with a hammer. Before, I had fought for hours with it and it wouldn't budge, but I guess sitting dry under a tarp all winter shrunk it a little.
                        So I can go on with my plan of replacing the transom.
                        • #13
                          I traced my new transom board onto 3/4 exterior plywood using the template I made from the old piece, and adding 4" to the height; cut the pieces out and glued them together with Gorilla glue & clamped and screwed together with 1 1/4" SS screws. This was the first time I used gorilla glue and I was a little surprised at how little it foamed out around the edges while it cured. I wondered if I'd applied enough, but the bottle says to use about 1/2 ounce per square foot and that's just about what I used, maybe a slight bit less.
                          Dry fit before gluing... a perfect fit:
                          ACX exterior from Lowe's, Gorilla glue & SS screws:
                          Another check after gluing:
                          I removed the dashboard tray and filled the holes in the dashboard with pieces of dowel glued in with carpenter's glue. For the bigger speedometer hole, I screwed a small backer board to the back of the dashboard and then glued in a piece of plywood I cut out with a jig saw (I later had to undo this one for mounting the tachometer). All the pieces are countersunk almost 1/8" and I'll level it up with plastic wood filler. I had originally planned to replace the dashboard, but it turned out that removing the original was more involved than I wanted to go. All I plan to put in the dashboard are switches for the lights & a bilge pump, and a 12v power outlet for a hand held spotlight.
                          • #14
                            I got all the bolt holes & drain tube holes drilled, did another trial fit and all lined up perfectly. It helped that I drilled the holes on a drill press so that kept everything perpendicular. That's JB Weld over the countersunk SS screw heads.
                            I also got a bunch of contact cement residue off the dashboard tray using paint stripper & polished it up with steel wool. It's pretty beat up so I plan to cover it with vinyl. Ordered an orbital sander from Harbor Freight for $20 in anticipation of painting prep.
                            I've also been thinking about what it will take to rig up the Johnson, so I can collect what I need. When I bought it, all it came with was the steering link that the steering cable hooks to, but no oil tank, controls, harness etc.
                            • #15
                              After a fair amount of research I decided to go with rack & pinion steering. The steering rack & cable are going to fit, but with the dash tray, that I was hoping to reinstall and keep to use, there's not going to be enough clearance for the steering wheel. I'd need about 2" more on the shaft length.
                              I could go without the tray and it wouldn't be that big a deal, but it would be nice to have somewhere handy to set soda, beer, sunglasses and misc. pocket stuff.
                              Originally posted by ezmobee View Post
                              I had the same problem. I ordered the teleflex wedge kit to angle the helm up higher which solved it for me.
                              I mocked up a couple 10 & 20 degree triangles out of cardboard to check what that would give me for clearance & went ahead and ordered the kit.
