sleddogs13
- Jun 11, 2009
- 20
Hi I am doing a restore for my Islander 221 almost done shoveling the foam out even in the cabin the transom is out.
Does anyone know rivet sizes for the hull and inside the boat and is it better to rerivit the hull if it leaks or put the sealant on the inside. I havinent tested the hull for leaks yet.
I was thinking about an aluminum floor no rot is this a good idea?
Also it has an OMC cobra outdrive. I am getting a new crate motor for her can I switch to a mercruiser outdrive?
Thanks! will post pics
