redneckvulcanrider
- Apr 27, 2014
- 90
? For everyone how do you do vertical fillets? Every thing I've done in the past I could move around to do them.
I like to use a bondo spreader to do final clean up and feather out the edges. Saves on sanding when it comes time to laying the CSM and the Fabric.
Roger Dodger on that Woody. What I like to do is get one of those same plastic spreaders..cut them to the profile ( or slightly smaller ) of the radius your trying to achieve. The sides are kinda auto-cleaning while your spreading your butter. Then..if you want to get real clean and tidy..you can grab an acetone rage and wipe off any residual stuff. Aaand if you have time to baby sit the thing..you can acetone wipe the fillet juust about when its gelling up so to smooth it out baby. Ooor..you can do what I do and get some resin on a brush and lightly coat the PB..to kinda smooth it out pretty like. Iiif you want to get all fancy and high tech about this..grab yourself some "peely-ply" from your local vacuum bagging supply store around the corner..Bam!..no sanding afterwards.
PS. Man..I think im over thinking this. Second thought..grab a half dozen Wendy's plastic freezy spoons and a zip lock
Humph, YD, you ain't seen nuttin till you've checked out the ULTIMATE FILLTETING TOOL...http://forums.iboats.com/forum/boat...-bateau-com-tw28-stretched/page11#post9931027
Polyester I'm not a big fan of epoxy have had issues with it before
Thats pretty snaz there Woody. Ive seen one of those before..now where was it..? Oh yea..a bird cage!
