Hey everyone, I recently acquired an old '61 (I believe) Duratech 15' aluminum in rough shape. I've since repaired several holes to the point that the boat now holds water when filled from the inside. I've got my hands on a 50 hp force motor and need some advice before mounting it. First and foremost I intend to replace the transom with new wood as the existing one is very soft. That being said the motor mount is quite a bit wider than the transom (Don't have dimensions off hand but can easily take measurements later tonight after work) I'd say about an inch, inch and a half difference at least. What is the best way to go about fitting the motor to this boat? Would I simply build out the transom with extra wood, or is there a better way to go about this? Any advice will be appreciated, I am hands-on, and automotive experienced, just new to boats and boating. Thanks for reading!
