The iboats forum moderators are excited to announce that at this time it appears the iboats forums posting pictures function is working once again. Though we cannot promise for how long, we're hoping for indefinitely.
Looks great, I'm nearly at this point and I've got a couple questions if you don't mind..
What brand vinyl did you use?
Are you going to screw the decking down through the vinyl or did you put it on afterwards?
Did you scrape all the glue off the aluminum before putting on the new carpet?
Thanks sub. I used nautolex vinyl flooring, The floor was good so I glued the vinyl directly to it, I scraped most of the glue off the aluminum before I reapplied new carpet.
Thanks for the info. I've been debating between carpeting everything on mine or doing it like yours with a vinyl deck and everything else carpeted. I was leaning towards carpeting everything but thankfully I haven't bought all the carpet yet because looking at your pics I think I've changed my mind again. Do you know what color that is. From the pics I can't tell if yours is the Storm Grey or possibly the Shark color.
Actually it's storm grey, and I personally think that vinyl is a better choice, easy to clean and doesn't hold moisture, your floor will last longer, it's more costly than carpet but will last longer.
Thanks JB, we're getting there, have everyting carpeted but it all needs to be reattached still dry fitted, hoping to get that done this weekend, then re install the motor and do the wiring.
