steely85
- Apr 18, 2015
- 121
Hey Iboaters. It has been a pleasure reading all over the forums for the last year. I have been planning, gathering, designing and prepping for the overhaul of my 1992 Crownline 196br. I have seen a few of the other builds of these same boats and I have followed friscoboater on youtube for a while. Days and days of reading and watching builds taking notes and taking names. Well that's my background and this is where I am now.
I started last week and my stringers are out up to my motor. I need to build a gantry tomorrow to take the motor out. Not my favorite idea but a builder buddy of mine is giving me a bunch of 2x10's. Cant beat free. Once those are out i will grind out the rest of the stringers and motor mounts. I have measured everything and drew everything on grid paper to scale. Once those are out I will start to be able to make my mock stringers and bulkheads. I'm planning on PL gluing the stringers in just for the ease since I am doing it by my lonesome. I will elevate them using Frisco boaters tip to use a few pieces of pink foam to prevent the boards bumping the hull. (I keep going back and forth on weather to use PL glue or Poly resin with cabosil.) As soon as the stringers are in I will be leaving for a week to go to Michigan, so I'm not too worried about the degassing of the PL glue. So I will need to make a decision within the next 4 days. I will probably go with poly with cabosil. Watching Jay mix it up seems less daunting than just thinking about the hassle of mixing every time I'm ready for more bedding.
I have also cut off my deck leaving a one inch strip around the edge to use as a guide to the proper deck height. I have researched and researched, googled and yahooed. Heck I even asked Jeeves. So here are the two questions I am trying to work out. I will be cutting the stringers taller than they need to be so I can cut them to proper height once they are bedded. However once the stringers are bedded how do I measure for the final height? Do I make sure my boat is level then use a level from the remaining deck lip out to the stringer?
Second question. What are people using to cut the stringers with once it is in the boat. The only thing I can think of is a circular saw and a jig saw. But what about the corners where the bulkhead and the stringers meet. Both of those tools would leave me with about 2-3 inches unless I angled the jig saw to get the corner a little bit better. Then use a hand held miter saw and or a belt sander to knock down the rest of the corner piece. Now that I am writing it down it is helping me with my own issues. I will probably use the circular saw, then switch to my hand saw to knock the corners down.
Thanks to all of your help. I love the boating community. I am from Michigan and grew up on the water. I have built cars, motorcycles and helped with houses but this is my first boat rebuild. I?m really surprised with my progress so far, I am much further than I thought I would be. Anyhow thanks for reading. Hope to hear some positive reinforcement on these subjects. I will update more with pictures later. I have to load them to photo bucket first.
