Stackmoney86
- Mar 14, 2015
- 29
Due to my jon boats size I've decided to venture into aluminum to use to add compartments onto my boat. None of the new aluminum is going to be weight bearing so I am able to pick up 36x36 sheets at local Home Depot for $20 bucks.
Never worked with aluminum before...it's always been steel welding or wood working. So looking for pointers and tips from those of you who have...with the cost of aluminum...want to keep mistakes at a minimum.
I do want smooth seams...rivets is okay as the boat is already covered in them. I do have a rivet gun already and since these do not need to be waterproof I can probably use regular rivets(going to research to see if there is a corrosion resistant rivet).
It's not going to be anything special. Just a base area for my all around white light. Electrical console for my few switches needed. And I plan on removing the front "seat" and close that in for a small storage area...and another flat area for lighting and a smaller battery possibly.
