dingbat
- Nov 20, 2001
- 15,502
It appears that moisture got behind the "filler" they used to fill the imperfections on the edges of the hardtop during manufacture and froze. The damaged started as small hair line cracks where horizontal met vertical and progressed into what you see in the attached photo. There are several locations that are starting to crack so a failure in these locations isn't to far off.
What's the best product to repair the damaged areas? I'm not sure if I'll finish the damaged areas with gelcoat or have the entire top repainted if that matters any.
