Todays progress
Once we got the motor off and removed many many rivets the top lifted off pretty easily
My garage is pretty small. I couldn't get the boat directly under a beam because of the way the storage above the rafters is set up so the rig slipped a little letting the boat come up crooked, but it worked
I think the area I will have to cut out is really pretty small. From the inside edges of those boxes that are in the aft corners up to these plywood supports by the sad looking blue carpet. The way the hull comes up there is really very little space between the deck and hull. It really seems to be just wide enough to attach the seats next to the ski locker.
The top of the transom with the inside being on top with a bolt visible. I am surprised the transom seems to be in really good shape other than the very top edge where the metal cap was.
This is the nastiest looking part that is currently visible. This plywood piece is right at the rear and is where the oil reservoir and gas tank sat. The oil was on the left in the picture where the metal bracket is and the gas can on the right where the stain is, the gas can is one of the plastic removable type, makes for easy fueling. There is no bracket for the battery so I guess it would just sit between the oil and gas cans??? That's where all the wires were laying before separating the boat into pieces.
With the plywood sheet removed, the wood there is soaked and you can see a little of the plywood that was under the fiberglass floor. No bilge pump and not much room for one either. That drain hole is going to let a little water stay in here to eat away at the wood, not that this boat seems to have much wood in it.
Tomorrow the cutting starts, pretty happy with what I got done today
