No Title
Hard to believe it only took a year for my first rebuild. Here are some before and after to show what was done.
The bow seating area:
The backing was all rotted we barely had enough to make templates to recreate the seats.
Helm:
The steering was frozen in place. A bit of work to get it apart but then I got lucky and it worked so it was a matter of cleaning the dried grease off it and regreasing the shaft.
The floor:
Soft and nasty, it took a lot of work with a wet vacuum to get all the water out of the bilge, the drain was clogged with leaves and debris from sitting out in the weather with no cover for a couple of years. Once the floor was removed the stringers fell apart so no template from them either. Probably the most tedious part of replacing the floor was trying to get them adjusted so the floor would sit right.
No amount of scrubbing with store bought and home made formulas will clean the stained port seats. A slipcover will have to do for now at least.
There was no cover for the battery area, a piece of marine vinyl to match the bow seats and trim and it looks much better.
For the trailer I added guide poles to make it easier to get the boat back on the trailer, they are lit at the top as well.
When we took the boat out for its splash test the boat would not plane. Being the very end of the season we didn't do anything with it last year. The prop had a dent in it that could have been causing cavatation so that was replaced along with a new hub as the propeller was slipping.
I have a new fuel filter on order. Nearly impossible to find one of the original fuel filters since they are no longer made but I found a company online that had 5 and is supposed to include the housing, that should be here this week and the motor will be done so it will be time to play
A couple of posts back I was talking about the windshield not sitting properly. I think what happened is that when I added the foam to the bow area there wasn't enough of a hole for extra to escape so it lifted the floor a little. Can't be fixed as far as I can tell without taking the floor back out and I am not worried about it enough to do that. I can't see any reason to ever want to close that section of windshield anyways.
