electrabishi
- Mar 13, 2015
- 18
I've had this Bayliner Victoria 2750 for a couple years and don't much like the low speed stability. I've been pondering deleting the command bridge and replacing with a flat hard top. I don't really carry anything up there, not even passengers. Here in Alaska its still pretty chilly to even drive up there anyway. There's got to be at least 200 lbs + to remove from topside which will help with stability. If it weren't for the stability and I wanted to carry my rubber boat up there its hard to find a convenient place with the seats, helm controls and railing. If I remove the command bridge and then put my little boat up there I'll still be down a hundred lbs topside. Has anyone seen this done or can point to another thread discussing it? I've been watching GWPSR thread on "1981 Bayliner Victoria 2750 - Restore or Bust" for a couple years now, I realize now he getting near the end of the hull I wanted to discuss topside work, but his Sunbridge is quite a bit different than my Command Bridge. I'll try to attach a photoshop of what I imagine my will look like after. Any comments?
Thanks
Thanks
