You can easily put 3-4 grand in one of these boats just to get them safe, and sea worthy. With all that money invested, we like them to look fresh and new as well.
Yours is actually a lot more work than mine was. Looks like you'll be at it for a while. I have about $1000 invested in mine and it is about ready for the water. I found that acitone helps out when your trying to get stuff to stick to fiberglass...I cleaned all my surfaces down with that when it came time for glass. Be prepared to use a lot of resin as well...I went through 6.5 gallons for the floor and stringers. If you have specific questions or need some advise, write Wes Hatch at Suburban Marine, he was very helpful. His father owned the Columbian boat fiberglass facility until they shut down in 78 or so. Real nice guy, and still into boats. They are only about 45 miles from me so I actually went and brought my motor lower end there for repair...We had a nice chat...
That stand is impressive...I used trailer jacks in each corner of mine because I was afraid that the hull was sagging from being on the trailer for so long (5 to 8 years with bad stringers) I put it in the water a week ago and realized that I never tuned the motor...it was a short day. But in the mean time I found that the transom was dust, and spent the last week or so replacing it. (I used the wood leftover from the floor and 9oz cross hatch fiberglass. it is almost back together and ready to tune the motor...then it's another test drive.
You are really getting it looking great, I hope you are having a good time working on it. I disliked some of the work but I feel very satisfied looking at it now!
As for glass. I used 6 oz on the stringers and around the flooring it was 12 inches wide but I cut it in half. the floor is 1.5oz chop strand, and the transom was 9 oz cross hatch. I used several types of resin, about 7 gallons in all (maybe 6.5) mine is 15.5 feet and was originally capable of 85hp, (it has a 50) but my rebuild beefed it up and I believe it could handle a 90. it is more solid than when it was new. (according to Wes Hatch)
Epoxy will kick azz! US composites seems like good pricing for me. 1708 , no matt backing. will do everything you need to on your GREAT WORK! :joyous: If you switch over to poly then use 1708 with matt backing. check their site, pretty informative. Even if you go to another vendor the info is a good read. If local man you have save a bundle on hazmat shipping.
