- Mar 8, 2009
- 43,633
Had trouble years ago with corrosion on my drive so I installed two additional anodes. The anodes came in a Merc kit and since then corrosion shows very little signs. When I installed, drilled 3/8 hole, passed the wires through, filled with silicone and secured with screws. I am seeing silicone is not the way to go. Even if it keeps the water out, water sitting in the bilge will slowly penetrate and soak into the transom wood core. What would you suggest as a better fix, 5200 or something else?
