I recently purchased a very nice 14' mirrocraft deep-V wide Aluminum boat with a 9.9 Johnson motor. I want to put a floor in it, about 4-6 inches off the bottom of the boat in each section between the 3 seats, in the back section, and create a platform over the front seat to the front of the boat. Ive been doing research into different flooring such as marine grade plywood, exterior plywood and composite decking. Id rather not go with any of the plywoods because Id pay $90+ a sheet for the marine grade and $40 a sheet for the ext. and still have to seal it with epoxy so if I can Id rather go with composite decking cause it would be durable and i would not have to seal it. I can get 1x6x8' composite decking for $10 a piece that weighs about 1.4 lbs a board foot. My questions are, has anyone had experience with composite decking for a boat floor and how well does it work? At 1.4 lbs a board foot is weight comparable to plywood? Any advice on mounting? Will marine carpet glue adhear to it? Any advice will be appreciated.
