Just bought a used 18" deck boat with livewell in front of console. It has fill tube near the top and a stand pipe with removable plug near bottom (about 2") and an open top for overflow. Livewell also has a drain hole in the bottom. This drain hole just drops straight to the bilge, no hose connecting it to anywhere. Assuming this is wrong, do they make a fitting I can secure from the top (screw on or whatever) that I can install and run a hose to the back of the boat on the other side of the livewell pump. Don't have access to bottom of livewell (fiberglass) for a two piece fitting. Thanks.
