Browndog10
- May 13, 2014
- 89
I purchased a boat a few months ago which seemed pretty solid, it turns out that it has rot throughout. I read somewhere that you should not buy a boat in winter. I wish I read that advice before my purchase. Well, everything seemed fine the few times out until I was in a bass tourney and had to use the livewell. I saw a bunch of water on the floor and turned the bilge on and I had alot of water coming out. Once I got home I started investigating and finding more and more bad signs.Turns out the elbow for the drain on the livewell was leaking and leaking badly and going straight to the floor and down to the hull of the boat. More investigation, I detected some rot in the transom and that brings us to this thread.
Time to start, I rented a cherry picker and pulled the motor. Started removing everything piece by piece.
After the cap was removed it was apparent that this transom was shot. I was really surprised that it was this bad. Surprised that this boat still floated.
I had to cut out some of the side panel to get the remaining bolts and screws fastening the transom. This took me the majority of the time as cutting the panel was last resort. Eventually, the transom was free.
I was hoping to get it all in one piece but it held together enough that I can still use as a template.
Unfortunately, the whole back end that held the batteries and fuel tank are rotten. Now this turns a transom replacement to a floor replacement also. Not too thrilled about this, but whats done is done.
Now my dilemma, hopefully someone can help. In order to pull these panels it looks like I have to drill through the solid rivets on the hull. I really dont want to if I can avoid it. They are above the water line but is there any way not to? The bottom is attached to the flooring would it compromise the integrity of the hull/rivets if I bend the side panels by just pulling them up from the bottom as much as I could? I know very little about solid rivets and they dont look like fun to mess with.
