Been a long time lurker on the forums and finally making a post.
After years of owning at least two boats (fishing vs. recreational sport), I'm down to one multipurpose boat now.
My current project is a 2001 Larson 190SEi runabout. I'm about to remove the old glued-down carpeting on the weekend. Depending on the deck condition either replace it or glass it in. Thanks to many great guides here I've got all the info I need for glass work.
I'm leaning towards a snap-on carpet on a boat like this but thought I'd check for any economical coatings that I can apply onto the deck and the ski-locker where paint is peeling somewhat on the fiberglass. My coatings selection is limited by what I can obtain locally even though I've got all the major hardware stores in the area.
My though is when I go fishing I can pull off the carpet to expose a tough coated surface which can be easily washed and doesn't get stained. And when it's time to do some tubing or relaxing the carpet goes back in. This way I can dry the carpet if it gets too soaked.
I searched the forums and found some ppl using Rustoleum ExpoxyShield garage floor paint with some success but there were concerns it wasn't UV-resistance and tends to chalk. So today while in a hardware store, I found this this guy:
RustOleum EpoxyShield Driveway Sealer Plus
On the label it says it's UV-resistant driveway sealer, made of used tires, jet black in color. Although I'd have to buy a 5gal pale, it's only like $25.
Has anyone used it on a boat deck before? Is it textured or something should be added to it for non-skid surface? Does it leach black when wet? Is it OK to use on fiberglass? Any thoughts?
