Browndog10
- May 13, 2014
- 89
Hi all, I am new to this forum and hope that you guys could help with some advice. I just bought an aluminum 1993 16ft Mirrocraft a few months ago. I have noticed that the transom has some rot but not sure where it can be dangerous. I figured with a 20 yr old boat that there would be some rot anyway. I started noticing this weekend when out on the water and I noticed that the livewell drain was leaking into the hull and I began my investigation more thoroughly than before. It seems like the transom on that side is rotted but the other side seems solid. When I bought the boat I pulled on the motor and there was minimal movement and did not notice any of the rot until I started searching a little more and started seeing screws that will not tighten with dark wood on the threads. I guess from reading some of the horror stories if you will, have me spooked as I bought this boat for family lake fishing trips with my two young boys and I certainly don't want to put them in any danger. By no means does this look remotely sagging, but indicators such as the splash guard drains being longer than the transom width and the loose screws have me concerned.
