Re: Epoxy sealing flooring plywood?
There are three types of resin used in boat building: polyester, vinyl ester, and epoxy resin. The majority of production fiberglass boats are built using polyester resin. There are different reasons to use each one.
As with any ?glue? they do not have all that much strength on their own, and all three normally need to be used in combination with some sort of ?textile? to achieve the intended strength (unless in the case of epoxy it is used as an actual ?glue? to cement two different items together).
Coating plywood with a resin is an effect method of sealing the wood from intrusion, however you need to realize that polyester resin is susceptible to water absorption (hygroscopic) and is therefore the least desirable of the three resin types for this.
If the resin coating is only a thin coating that is absorbed into the surface of the wood then a layer of textile is not necessary. If any buildup of thickness is desired (as in a smooth finished surface), then some sort of textile (fiberglass cloth) should be used in order to achieve a desired coating strength.
As has been mentioned, for the deck on a bass boat, simply painting the plywood with a good quality oil based enamel (and maintaining it) will last for decades . An oil based enamel paint IS a better option (tougher, longer lasting, better UV resistance) than varnish for sealing wood and keeping out moisture.
