Hi all. I bought a 1981 Gibson houseboat a month ago. I have been reading quite a bit on this forum for tips. Once I pulled the old carpet to replace, I opened up Pandoras box and found numerous spot of rotten wood from leaks. The price wasnt too bad though and I absolutely love the lake its on (about a ten year waiting list to get on it). It does tick me off all the bad wood was blatantly covered and painted for the sale. At this point I have spent all off hours last two weeks gutting and replacing the old wood.
The first question I have is how to seal the hull to the deck? There are no rails or rivets. I am considering using 5200 on the outside and fiberglassstrips on the inside.I have done extensive work to structurally stregthen the woodwork inside to hold everything together.
Next, how do I seal wood to the fiberglass hull on the inside? I can screw the lower half into studs, but the upper plywood needs to be glued. Do I use resin, liquid nails, something else? The surface is rather bumpy.
Last, I need to fibergalss the wood repairs I made on the deck. Is fiberglass resin and matt from home depot ok (I am going to paint over it as well), or do I need marine epoxy
Once construction phase is done, I will have more questions regarding solar, shower drain system, , waste tanks, etc..
Thanks for any help or tips!
