Re: Is it necessary to seal marine plywood??
REAL Marine Plywood will meet a standard called BS 1088 and will that will be stamped on the product. This stuff is INCREDIBLY EXPENSIVE, because it use a special rot resistant wood called Okoum?. It is difficult to find. The good news, is that it requires no coating to be rot resistant. It is typically sold in metric thicknesses and you can actually downsize (5/8" instead of 3/4") because it uses more thinner layers.
What most stores sell as "marine grade" plywood use Douglas Fir for the outer plys and SPF for inner plys. It does use waterproof glue and has more layers like the BS 1088. It is still expensive.
I would use a good grade of plywood (like AC, not CDX). Drive fit the floor. Remove. Fill all edge voids with some kind of epoxy and let harden. Then mix up 1 part oil based spar varnish, 1 part linseed oil and 2 parts mineral spirits (paint thinner) apply 1 very heavy coat to all sides and edges. Saturate the edges. This will take 2-4 days to dry, depending on the temp.
More work, less money and it will last a long, LONG time.
