Hello, Garett here and this is my first post, I've done a lot of searching to find what I'm looking for but the rules say to start new threads rather then post in old so here I am.
I was given an old crysler satellite. I knew it needed a new transom which I've started replacing. It's now looking as though I need a new floor, so thought I'd start a thread to hopefully get some help along the way.
I've attached some pics of where I am at so far. The floor feels rock solid underfoot it wasn't until I removed the transom that I found wet foam and plywood. I drilled a one inch hole closer to the front and it appears to be the same.
So my question is if I rip this out can I replace the foam with sheets of closed cell foam insulation rather then pour in place foam and on top of that would I be able to put a plank deck down rather then plywood and fiberglass.
Thanks for looking and for any help I intend to see this project through and keep the thread updated for those interested.
Thanks again
Garett
Thanks again
Garett
