Re: Fiberglass Repair Question
The following is a somewhat simplified, but accurate description of the what you will need to do to effect a solid repair...
After you clear away the rub rail and any other bright work or hardware in the way...start grinding away all the bad glass...
Go as far as necessary to get to good, uncracked, solid glass, approximately to where the orange ovals are...
Create a shallow dished area with the green ovals being the deepest areas and the orange areas being pretty much flush with the surface...if possible, try to get to the inner most layer of glass, without breaking through... but if you do, no biggie...
If the inner most layers survives, then begin laying in progressively larger pieces of CSM [1.5oz.] and 1708 biaxial, until you reach the desired hull/cap thickness...
Depending on whether you are going to paint or gel coat, the final height of the glass should be level with the surrounding area if painting, or just shy, by about the thickness of a penny for gel coat...
If you happen to break through the inner layer, just create a dam out of some wood or cardboard covered with wax paper and proceed as above...
If done correctly, that should be a solid enough repair...
If you want to add additional strength, you could grind a slightly dished area on the inner skin and apply a couple of extra layers of CSM and 1708 in the same manner as the outside...
Take your time and make sure your laminations are as bubble free as possible...
Good luck and be sure to keep us posted on your progress, plus if you have any additional questions, fire away...
Here are a couple of sketches...
Where to grind...
Applying laminations...
