It was suggested in another thread that I start a dedicated thread to the rebuild of my boat. This way everyone could keep track of the progress and decisions made. So here we have it. This is the beginning of my long journey into pain and agony. LOL
The reason for this rebuild was that the floor had a soft spot near the ski locker and another in the rear passenger portion. Carpet was shot and the boat just needed a good overhaul. Seems very solid, but just has several years on it.
I do not have any pics yet as I just havent taken any. If the weather holds for tomorrow ill get out and take some.
So far here is what I have accomplished.
I know everyone is going to scream that if the floor was bad then the stringers are bad. That may indeed end up being true but for now I can tell you that I dont see that as being true. When I pull up the rest of the floor ill know for sure. So for now im going with they are good.
My intentions were to replace the floor and all seating / console structures. Then coat everything in some sort of bed coating like Monstaliner or al's etc.
The issue I am running into now is glue removal. I have tried grinding the stuff with no avail. I purchased a wire wheel for my grinder and it does remove some. It ultimately only ends up smearing a bunch of it. I also purchased a gallon of adhesive stipper which also removes some glue, but still leaves a very smeary, sticky surface even after 3 applications.
So as of today the glue is my "sticking" point. No pun intended. I do not want to coat over a sticky mess with bed liner. Im not even sure if it would be safe to apply carpet over the stuff if I gave up.
Any hints as to getting around this mess we call carpet glue. I never in my wildest dreams thought that glue would be a harder task than actually removing or re installing the floor. It so far is proving me wrong.
Thanks
- Removed the structure under driver and passenger console.
- Removed the structure which held up the front seats for the open bow
- Drilled several test holes in the stringers where space allowed to check for water intrusion or rot. So far all negative.
Thanks
