Evening guys,
i am about to fix my new transom to my glastron CV19, the transom has had West Epoxy resin applied to seal the wood before fixing. Will 3M 5200 adhesive adhere to the epoxy coated ply? I am aware that polyester resin will not adhere to any surface with West Epoxy on it so want to check before i use the 5200 and attach the transom to the hull.
Last thing i want is to do all the work and the joint to fail:-(
Many thanks in advance.
colin
colin
