Im almost to the point where I can cut the floor out of my boat. I have read a couple ways to do this. One where you cut as close as you can to the hull then grind it flush. The other where you leave a few inches out which allows a little flat area to glass too. Is there a recommended way>
My thoughts were that if I leave a few inches I would cut in a 45 degree angle. This would allow a larger lip which I hopefully can squeeze some pb into. Smooth that off then glass over it. My floor is solid for the most part other than in a few central areas. So im not really worried about rotten wood near the hull.
Any thoughts or accepted methods?
Thanks
Thanks
