Re: Removing snap clips from aluminum windshield frames
Those slide snaps ? You could remove some of the frame and slide them out..or you can tape next to them ( trying not to damage the frame) and pry them out with a screwdriver. I personally use a dremel with a wafer cut off wheel to cut the clip a bit before I do the pry out .
