OK I have a 19' Keywest 1900 open fisherman an the steering is stiff, took the outboard off an steering still has tension, so I picked up a parts boat that I'm using the engine off if an the steering is very easy an noticed it has a tack an pinion steering set up. The cable itself will probably not be long enough cause the parts boat is only a 16' an mine is a 19'.
My question is it worth it to change out my current set up to this rack an pininion an just buy a long enough cable?
