Got some good weather a couple weekends back and got the chance to get started on my transom replacement. This picture shows the individual tiles being laid out on the foam that I used to pattern the transom. I stole some of the wife's tack paper and taped it onto the foam so that I could keep the individual pieces in the right place when I moved them around.
I then mixed up the epoxy glue to mayo consistency and glued the individual pieces to the transom. This picture shows the first couple of rows with the clamping sticks in place......this ended up being the most time consuming part of the job since each stick had to be cut to the correct length.
The last pic shows all pieces glued in place and PB fillets around the perimeter of the transom.
Temps are supposed to be in the mid 40's this weekend so I should be able to get the building to glassing temps with the wood burner. All of the threads that I have read have a transom made of a solid piece of wood which gets the first layer of glass on it before being glued to the transom. It is then tabbed into place. Since mine is made up of the individual tiles, I am thinking that I should now proceed with one layer of cloth over the transom wood to join all of the tiles together then tab that to the hull. Hopefully this all makes some sense ...... if not, I am always open to suggestions from those that have been there & done that.
