Re: Ratio of MEKP to Poly Resin
On the label if my poly resin, it says to mix at 1% at 20 degrees C. Depending on what I'm doing (soaking plywood, mixing PB, laying glass), I have been mixing anywhere between 1% and 1.5%. I will usually get 20-30 minutes working time before it starts to kick. It stays tacky for a couple hours before really setting up, overnight it becomes rock solid. That is for my particular resin, double check with your particular manufacturer.
