I'm in the process of repainting my outdrive. I'm scuffing the whole outdrive keeping the original Factory Volvo Penta paint where able and sanding to bare aluminum in spots to get rid of corrosion. I'm alumaprepping the aluminum areas then sealing it with rattle can zinc chromate to prevent corrosion before I can top coat everything. I plan to then use polymide epoxy primer and top it with Supermarine Ironside urethane. My question is: before I spray the epoxy primer do the zinc chromate covered areas need to be scuffed again? Or will the epoxy primer bite into the zinc chromate on its own?
