hooked jon boat
Mud Puppy
Re: hooked jon boat
I'm not a Tin Can guy, but my day job is working Aircraft Flight Structures where we do aluminum and composite repairs all day long.
Pictures would help those in the know about AL boats! I'm sure they are very similar repairs to the ones I design; cutting out the damage, making a tight filler and putting a repair doubler on the back side of the filler, the repair doubler being larger and blind riveting or epoxying everything together. On the blind rivets, you want something that locks the stem to keep it from falling out, or you will need to seal the stem when using a regular pop rivet.
bigcountry5585
Re: hooked jon boat
Thank you sir. I personally can't see the "hook" but have had several people look at it and say its hooked. How do I check this? What am I looking for?
Mud Puppy
Re: hooked jon boat
Guess I was taking this literately as a gouge or a crack. I'm not sure what a "hooked" boat means either!? :noidea:
But I would think anything broken can be fixed, just depends on what it is, and to what lengths one is willing to take.
Good luck; I'll just ride along and learn as well! Someone will know how to help!
Re: hooked jon boat
Ayuh,.... Get a 4' to 6' straight edge, 'n hold it to the bottom of the hull, from the transom edge, forward,....
Yer lookin' for Air, 'tween the straight edge, 'n the hull,...
Bob_VT
Re: hooked jon boat
Your boat is over powered with a max rating of 25HP and you are running a 35HP. You have questioned about a hydrofoil, a power tilt trim system and a jack plate. The primary reason your boat is not handling properly is because you are exceeding the USCG Max HP recommendation and the boat was designed and only approved for 25 hp thus about 30% above the limit.
When a boat is rated for a tiller that rating is always lower then a control console system design.
That is the reason it bounces. There is a possibility that you could have a damaged hull from extended use of a higher hp.
jbcurt00
Re: hooked jon boat
I completely agree w/ Bob.
A 14ft flat bottom jon boat:
have an old 1978 Lowe 1448 flat bottom jon boat with a 1976 Evinrude 35 tiller handle motor. Its a short shaft motor. I weigh 360 lbs, 6 gallons of fuel, and a battery in the back of the boat. When I first put the motor on this boat, I put the tilt pin in the first hole closest to the boat so I wouldn't flip.it over. I ran full throttle for miles on the river and it did fine but felt like it was dragging something behind it and the bow was plowing into the water. A couple weeks later I put it on a smaller river and decided to put the pin in the second hole hoping it would raise the bow but it really didn't. The problem is that when I was at 3/4 throttle it did fine, but when I increased to full throttle the boat would suddenly stop, and veer hard to the left. The cavitation plate is approximately 1/2"-3/4" above the bottom of the boat. Is it possible to get the boat to ride more on the stern instead of plowing down in the front.
Flip the boat over???
I think there are other factors contributing to the problems you are having w/ this boat & motor.
Boats don't have brakes, so I'm not sure what you mean when you say: The boat suddenly stops
A hard veer to the left indicates an unstable craft, which could certainly be dangerously unstable.
The other thread(s) you have about this boat/motor combination and the problems you describe make me think that the boat is possibly overloaded, and probably improperly loaded w/ weight fore-aft/port-starboard.
For informational purposes this is generally what is meant by a boat hull having hook(as Bondo describes):
I don't know that a 14ft jon boat's hull could develop a severe enough hook to be noticeable, but by overpowering the boat, you are adding additional stress to the transom. The heaiver & more powerful 35hp you're running could conceivably act as a lever, pushing forward at the prop, wrenches the powerhead & transom mount rearward. Pulling the transom rearward at the top edge pushes the transom forward at the bottom of the hull. This in turn would cause the bottom of the hull to be pushed upward (not unlike a hook) but I'd describe it more as a buckling.
In a lightweight 14ft jon boat, designed for a 25hp OB, I wouldn't be surprised that at rest there is very little indication that this ^^^ is happening. Underway, fully loaded & at WOT, it could certainly manifest and create the unstable & dangerous conditions you describe.....
Boat safely, in part by following the manufacturer's max hp ratings.
bigcountry5585
Re: hooked jon boat
Thanks for the input. I'm thinking about selling the 35 and looking for a 25. Do you think this will cure mostof the issue?
