GA Paramedic
- May 30, 2006
- 103
I have a 1976 18' ski boat with a false floor in it due to rot of the origional one. I put 3/4" PT plywood and I/O carpet. the 2" drywall screws that I used to secure the floor down didn't seem to grip tight but they are holding everything down so far. The boat had a tripod ski pole when I got it. The quick disconnects are in good shape and are secure on top of the transom. The pole is in great shape and I have a mount for the pole to the floor that is secured with 8 lag screws and one bolt through the pole. Will this be safe to pull a skier or tube or kneeboard if the base of the pole is secured to the false floor? My concern would be the pole would be pulled upwards when pressure is applied and it would pull the false floor out of the bottom of the boat.
