I purchased some nida core 3mm laminate bulker. Is there any special way to apply it? I plan to lay a layer of 22 oz cloth on the old laminate. Then add the bulker and top it with more 22 oz cloth. Can you double the bulker if need be? For example add 2 layers of 3 mil to make 6 mil? If so do you have to add a layer of class in between? I'm also using epoxy for this.
Thanks,
Thanks,
