Re: 68 AristoCraft 8-teen off and running
Old Guy marine mechanics forgot about them. Went to by a Holley rebuild kit for a 780 cfm. double pumper. The marine rebuild kit has a different design power valve & accelerator pump assembly's, he pulled the parts kit, asked what type of boat it was going on, I told him I was using it on a LT-1 powered 70 Nova SS, he pulled the part back telling me it was against the law to put marine parts on cars, federal law no less and he wasn't selling it any yea-hoos. That was a shocker, my brother and I walked out laughing, what you going to do with old mechanics?
Never seen anything but multi layer steel cylinder head gaskets which are commonly used on performance street motors and boosted engines, as far as extra impregnated silicone in pistons I doubt this and will research the validity of the statement. Mercruiser used the process on the large bore racing motors piston BORES based on a process developed in 1967 by Mahle allowing aluminum pistons and aluminum sleeves or aluminum blocks to attain tighter tolerances between the piston & the bore However, the sulfur found in much of the low-quality gasoline caused some Nikasil cylinders to break down over time, causing costly engine failures. Inquire @ your local BMW dealer about that debacle.
I did recognize and said I believe that the cam profiles could be different and were different in some applications, this is not necessary in the LS series engines which develop torque tipping off idle; peak torque is developed @ 4900 rpm measuring 345 lb. ft. which is a scant 400 rpm above the WOT max of the 2.5 120hp while attaining peak power of 353 @ 5200 rpm. The cam in this case is not an issue. The head gaskets are MLS as well had they not been I would have added them during the soft rebuild.
I said Mercruiser is using the automotive engine management system albeit in a water proof case, not because diodes, chips and resistors spark, because water and electronics do not mix well, same reason the connections on the various sensors are weather-packs from the automotive industry suppliers, keeps moisture out.
Based on the power to weight ratio, final drive ratio of the Bravo 1 (with the correct prop size and pitch), I believe this boat will cruise all day long easily @ 60mph turning 2800-3200 rpm on plane which works out to 46-53% load on the drivetrain. There will be no 80% load 90% of the time, somebody can't build an efficient powertrain if this is the case.
BTW the old mechanic guy needs to watch some real auto racing like Formula one, or the Grand Prix bikes where the norm is 100% load 100% of the time for as long as 24 hours without glitching. Love new technology, offshore unlimited are another 100/100 using highly built automotive derived big block tall deck aluminum motors running superchargers on each bank of pistons.
And Yes, not only do I want to use this series car engine in a boat, I do believe I'll do a few more and sell them when I finish this one, I'm already looking for a few more derelict 8-Teens to modify.
I like this forum...really
p.s one that runs 100% 100% of the time except when docking or no wake zones, splashed in 2002 having replaced one lower unit for a failed prop shaft, lost a $2500 lab prop as well, otherwise, tune-ups and seals
Belongs to one of the pals, the tool engineer
