I have a Sea Ray a 1984
Sea Ray used a vanieer on all surfaces looking like a wood stain
Boat is a fisherman model. stern has no seats,. engine cover but lots of this vanier on stern and gunnel sides
Corners finished in real teak
Years of rain & sun plastic surface is bleached worn and tired
Wood is okay I can use as a form for new starboard which would be expensive and outlast boat or replace with marine grade ply wood and stain.
Just did not want too occur that expense, & work , just wanted too clean up and make it look better
I used a over counter stain and took days too dry
Back too paint store I find out because I am going over
a plastic surface a varnish will not dry I need a gel varnish
Box stores only had two colors, both dark
Did purchase a dark gel, and when applied I was not happy how it was covering.
I ended up using the gel stain like a paint covering all areas , no stain streaking look just dark paint
I sanded one area back too the vanier next too the dark gel, both look poor
So what would you guys recommend something in a paint just too cover, clean up and look professional
thanks
thanks
